'long' data type problem
ibrahim03
Full Member level 1
Full Member level 1
avr studio datatypes
I am trying to write sectors to a mmc card. I am using the following method to write the sectors:
unsigned char MMC_WRITE_BLOCK( unsigned int SECTOR,unsigned char WRT)
	unsigned char LPCNT=0;
	unsigned long ADDRESS = 0;
	ADDRESS=SECTOR*512;		//PROBLEM : 'ADDRESS' does not hold a value larger
					//           than 65535 !!
/*-----------------------CMD24--------------------------------------*/
	SPIPORT &= ~CS;
	CHAR_SPI( 0x58);
	CHAR_SPI (ADDRESS>>24); CHAR_SPI (ADDRESS>>16);
	CHAR_SPI (ADDRESS>>8); CHAR_SPI (ADDRESS>>0);
	CHAR_SPI( 0xFF);
the code works fine for smaller addresses but when the address value exceeds 65535 it 'rolls over'.
I mean if I define
SECTOR = 160 then the address will be calculated as
ADDRESS = SECTOR*512 = 16384 !!
which should be wrong (correct value should be 81920) because I have defined ADDRESS as 'unsigned long' and that should be 32 bits. But why is it acting as 16 bits ?
I am using WINAVR-20050214 and AVR Studio 4.12 to compile my program.I am not using the latest version because with that AVR Studio wont simulate the code with it.
I tried to solve the problem by defining ADDRESS as uint32_t but that was no good either.
I even compiled the code with Imagecraft C compiler ICC AVR but still I had the same problem.
Can anyone please identify the problem over here.How can I (actually) define ADDRESS as a 32 bit number?
Shot in the dark,
Try ADDRESS = (unsigned long)SECTOR * 512UL
    ibrahim03
unsigned int sector;
unsigned long address;
sector=160;
address=(unsigned long)sector*512;
it works fine:D
    ibrahim03
Good!
This is a dangerous inconsistency in the c language of type widening in integral promotion. It is safer never to rely on the widening type afforded by integral promotion.
Misra rule 10.6 (Required) A "U" suffix shall be applied to all constants of unsigned type.
So use '512UL'
