erpgc82
Junior Member level 1
Hello friends, I'm new to microcontroller programming and I came across a situation.
Micro in 3.3v, 18LF26K22 and I could not understand if it supports in SDA and SCL 5V. It will be connected to the ds1307 at 5v.
I couldn't understand whether I need YES or NO.
Some say it is necessary to use a logic level converter, others say that it is enough to connect the pull-up resistor to 3.3v.
After all, can I use only the pull-up or do I need to assemble a logic level converter circuit ??
