Logic Probe Pulsar, when is it best to use it?
danny davis
Banned
Advanced Member level 2
Hollywood
When is it best to use a logic probe pulsar? to test what kind of logic IC chips?
How do you guys use a logic probe pulsar, for what use?
Imagine that you have some logic inputs connected to one output. One input is faulty and closes on the ground. Required to determine - which of them. Put the output pulse and logic probe watch status change chips connected to this output. Faulty chip status has not changed. Eureka!
How is a logic pulsar different than a function generator? Does a logic Pulsar do anything different that it's ment for logic troubleshooting?
The function generator has different waveforms (square, triangle, sine wave) amplitude and frequency of which can be changed. Pulse generator - the TTL / CMOS single pulse and may be square wave.
It is not likely, but this depends on your fantasies.
The Hewlett Packard kit we had used a pulser and a current probe. If you had a node that was stuck you put the pulsar on it and with the current probe you could then trace where the current was going to. i.e. the short to deck, blown up output. .. .
Frank
A Pulsar is a star that is emitting light rays , hence " pulsing", like a galatic light house.
Why is it bad to put +5 volts on the output of a TTL or CMOS chip? don't they output +5 volts HIGH signal
So I should Inject the +5 volts NOT on the output but a near by component after the output?
What you mean by the opposite voltage level? it's either zero LOW or +5 HIGH
If I apply +5 volts to a LOW signal that will cause a SHORT?
Load component is out of range, you will damage chip.
The same thing.
If ootput is LOW - HIGH and vice versa.
If you apply continuously +5 volts to a LOW signal and vice versa that will cause a SHORT.
So what continuous voltage can I apply on the output of a TTL or CMOS chip? 2 or 3 volts is that safe?
Is that why they use the logic pulsar because its not a continuous voltage and its a short duration to cause damage to the output of a TTL or CMOS chip?
What voltage can I apply to the output that is continuous DC voltage that is safe?
Do not apply load, short on +5 or GND is applied zero impedance.
To cause no damage to the output of a TTL or CMOS chip.
When there is no load on a TTL or CMOS chip , what output signal is?
Is a pull up or pull down resistor a Load? what is a load? what can i use as a load on the output of a TTL or CMOS chip?
what continuous voltage can I apply on the input or output of a TTL or CMOS chip that is safe?
You can put any voltage between 0V and Vcc on an input. You should not put any continuous voltage above about 100mV on an output. When an output is in use there is a transistor that is switched on either between the +Vcc line and the output pin or between earth and the output pin. So putting any voltage into the output pin can cause the switched on transistor to draw excessive current from your voltage source and burn out. A pulser put out a very narrow pulse so even if the transistor draws excessive current it does not have time to heat up and destroy its self.
Frank
The Logic Pulser has a switchable pulse rate either 0.5hz or 400hz
Using a oscilloscope to view the logic pulser signal at 0.5hz is hard to view and also 400hz is also to view on my oscilloscope
