Logic level converter IC
jerryvdk
Member level 1
Member level 1
Does any one knows an ic/circuit that can convert a dc level(10-30V dc ) to TTL level?
If the 10-30V will always be driving the TTL input, use a resistor voltage divider into an op-amp comparator.
Well, in case of TTL output i.e. 5V, you can also use a voltage Regulator IC which is LM7805 .. It gives constant 5V at output and input range is also upto 25V to 30V .. Read datasheet of lm7805 as well :) ..
it depends on switching thresholds.
Specify:
* the max. input voltage to get LOW output
* the min. input voltage to get HIGH output
Klaus
Please specify purpose like switching speed, direction, current source and sink capabilities, etc.
Analog Devices have a very good range of isolators.
Link
74lvs4245 or 74act125
