log2(n) in Verilog without using +, -, *, /, ** or $clog2
Đô Đô
I'm trying to write Verilog code to compute a base 2 log value of x, where x is an unsigned 16 bit number. At my teacher's request, I can't use Verilog's built-in function ($clog2) or built-in math operations like *, /, +, -, **. So it gives me a lot of trouble. Please help.
What input range?
(What output range?)
What precision?
If you are interested in integer output, then just return the position of the most left (MB) "1" in the input data.
Examples:
* input 8 = 0x08 = 0b00001000
In the binary representation the "1" is at bit3 --> the result is 3
* input is 128 --> 0b10000000 --> the "1" is at bit7 --> the result is 7
Klaus
Reactions: Đô Đô
    Đô Đô
    Oh that's great, so what's the working principle for it?. And how am I going to do that? I am a beginner. Thank you
What input range?
What precision?
Examples:
Klaus
Oh that's great, does this apply to numbers that are not divisible by 2, if i just take the integer ? So what's the working principle for it ?. And how am I going to do that? I am a beginner. Thank you
what about my questions?
Did you try/read/draw something on your own?
Klaus
Consider that the purpose may be to merge two unrelated math calculations into one exercise:
(a) how to express fractions in base 2 (besides integers),
(b) how to approach logarithms in base 2. (And the counterpart which is exponents containing fractions.)
I suspect the teacher wishes not for a 'pat answer' from a message board, but your own expansion on concepts learned in school normally in base ten.
