The AX-31B antenna is a compact VHF/UHF directional antenna with an in-built amplifier, which provides a low-cost alternative to conventional VHF/UHF antennas (for example discones), especially for indoor professional and amateur applications. https://www.winradio.com/home/ax31b.htm
