local oscillator with phase shift
david753
Full Member level 1
Full Member level 1
I'd like to design a BPSK receiver recently.
In my first idea, the structure of receiver is described as following.
Antenna-->LNA-->RF to IF-->IF AMP--> IF signal multifies LOCAL OSCILLATOR-->AD CONVERTER.--> DIGITAL CIRCUIT PROCESS (retrieve baseband data).
In local oscillator, the phase of local oscillator have to be locked in the correct position in order to get the most clarify .
please refer to as following link that shows the signal after IF signal multifies local signal.
My idea is to feedback the AD converter output to local oscillator, threfore to make a closed looop system that shifts its phase.
My question is,
where can I get relevant ICs or circuits about this local oscillator that produces 26MHZ signal?
