malli_1729
Full Member level 5
For one of my project, i am looking at Switching power to the extender boards from main board.
I am doing the feasibility analysis of Load Switch or discrete implementation using nMOS or pMOS.In that process i have encountered this point which i am not clear.
"When using an N−channel MOSFET in a load switch circuit, the drain is connected directly to the input voltage rail and the source is connected to the load" and
"When using a P−channel MOSFET in a load switch circuit (as in Figure 1, the source is directly connected to the input voltage rail and the drain is connected to the load"
My doubt is:
When we are using nMOS anyway we need extra rail to be connected to Gate terminal so, that Vgs >= Vth +vin(Load to be switched). So, this doesn't matter whether we connect input(vin) to either S or D ( we can intercahnge S and D). any other consideration why D will be connected to Vin and S will be Load ?
Same for P-MOS also.
My doubt is:
