Ericwatson
Banned
![Junior Member level 3](/styles/images/ranks/clevel3.gif)
What is the Lo Z mode on fluke DMM meters used for?
Is it better to test transistors in a Lo Z mode because it loads the transistors junctions to measure leakage?
Technicians have told me to use older Lo Z analog meters to measure a battery because the Lo Z input circuit loads the battery. What other kinds of components would be better to set with Lo Z or want to add a circuit load during measurement?
Can I take a new Fluke DMM meter that has a 10 meg impedance and put a 10K or 1K in parallel across the red and black jacks on my fluke meter to make it a Lo Z meter?
Older analog meters loaded down the circuit when measuring voltages and resistances. How do Electronic technicians back in the 60's make voltage and resistance measurements when the meters was loading it down?
