STOIKOV
Full Member level 4
in mixers' designs I've read in books or papers that the LO is specified in dBm. This means dB relative to miliwatts at 50ohm load or dB relative to milivolts ? supposing the LO is a square wave.
well , i am not sure about that i think square wave is ideal for switching as it gives maximum slope and hence more ideal switching , where near ideal switching gives at least better noise performance and better linearitybiff44 said:Mixers do not work well with square waves as the LO signal. That is because a mixer is pretty much an analog sampler, and if you do not give it a sine wave at the LO port like it wants to see, the sampling function gets screwed up.
So your orignal question is similar to asking "what miles per gallon does my car get if I use corn syrup instead of gas in the tank"! The answer is simply, who knows if you can even get the car started, let alone a specific detail like miles/gallon.
