LNA mixed-signal mode Noise Figure de-embeding
fred3991
Member level 1
Member level 1
Hi everyone,
I was wondering if it is possible to get NF from Single-ended to differential LNA measurements using Friis formula?
The complete measurement setup looks like this
I need to determine the NF for the LNA.
I have checked this solution using matlab.
(lets Assume that the NF for this LNA is 4 dB***)
Result in matlab
Is this approach acceptable and correct, or should other deembedding techniques be used to determine NF for LNA?
Thanks in advance for any information and ideas provided.
It's principally correct. Either single ended or differential, the Friis Equation is always identical.
I didn't check Matlab script, no idea.
In matlab I just symbolically solved the NF of stage 2 (LNA) from Friis, and then solved this equation and got again the value of NF =4 dB
