huytergan
Member level 3
I know when I have two port LNA, I can use VNA to get its gain i.e S21.
However, how can I measure its S21 when I terminated its input? For example, if we have a board that includes a patch antenna at the input and its ground plane soldered to the PCB ground and fed with via to PCB top. So there is nothing to be connectorized at the input, only one output connectorized at the board, but board includes chip LNAs on the path. So I have only one out and zero input for VNA. How the LNA gain is going to be measured?
