Re: LNA DESIGNING
hi,
i am working in DCS Band (1710MHz-1880MHz). i want to know what is the right way of an LNA design. i could start with inupt output matching here how can i start i mean first input then out put Or both at a time ( Γl and Γs are interlinked with S11,S22,S21 etc) so i don't have clear idea. like that to get max gain with low NF.
how i can tackle the issue .for biasing i have more doubt, s-parameters are already in biased condition does it mean inside the transistor chip biasing ckt already exist!
or different. then suppose biasing is given 4 V, 20 mA in s-parameter data for a chip, means, if i simply connect (with proper filtering) 4 V supply it will automatically take 20 mA current ( because biasing ckt is already exists inside the chip !) or i have to make 20 mA by adjusting resistor externally.
and one more can you please give me an idea how to select NF circle Gain circle (which gain circle i should consider there are different kind of gain circle) in ADS.
i think you will realise my doubts
hoping a kind solution
thanks in advance to you
Added after 9 minutes:
hi david,
your papers are really nice, it clears my doubts. thank you (although i know it's toomuch less !)
david, i have been in lna design in DCS band (1717mhz-1880mhz)
here should i go with lumped element for input / output matching or i follow distributed matching?
please suggest me
thank you in advance.
sarkar.
