LNA Design @ 2.4 GHz using Serenade....Help Plz
abhinavs
rf simulation serenade
Hey man I am pretty new to this field and my professor has given me this task. I have to design an amplifier at 2.4 GHz using FR-4 i.e epsilonr=4.4 and h=1.6 mm.
Further I need to design this amplifier with matching n biasing network for GSM (900 MHz) frequency.
I need to do all this on Serenade. I tried out several tutorials but i m unable to understand how to design the amplifier.
I will be thankfull if you can lemme know how to go abt it.
I will be grtful if you can mail me the simulation files, if in case u have alrady attempted this problem.
mail me at : mailsforabhinav@gmail.com
Hoping for your kind help,
Abhinav
2.4ghz lna
We need more details regarding the specification of your LNA: Gain, NF... to be able to help you.
regards.
2.4ghz lna design
what is the transistor u will use ? , check the application notes of www.avagotech.com
and the book of gonzales , it is very important for LNA design
khouly
design 2.4ghz lna
well specifications are
gain > 10dB
Noise Figure < 2-3 dB
BW of 100 MHz btween 2.4 GHz to 2.5 GHz
BJT AT-31011 cabe used, however my professor said you r free to choose any.
Rest i m too weak in this field , i myself dont know wat to use.
Pllllllllzzzzzzzzzzzzzz Help
design of 2.5ghz lna
Hello All,
I need the help on the problem urgently. If anyone of you have any sort of help for me regarding the 2.4 GHz LNA design, kindly lemme know. Mail me the serenade simulation files to mailsforabhinav@gmail.com
schematic lna ghz
check the tutorials given on this forum
I think this will help you.
best of luck
Abhishekabs
serenade simulation
I need to submit a report for my degree, which is regarding 2.4 GHz LNA design.
My prof has asked me to design the LNA using "Serenade", also I have to use FR4 substrate i.e. epsilonr=4.4 and h=1.6 mm. Other specifications he asked me to meet are:
gain > 10dB
BJT AT-31011 can be used, however my professor said you r free to choose any.
I look to you for some help. If in case smone can mail me his/her simulation files that will be of great help to me and get rid of this course.
I am really in trouble coz this is really not a field of my interest, but I need to complete this for my degree.
Lemme know if you can be of help to me, exact specifications doesnt matter at this point of time.
Looking for your kind help,
Thanx in advance,
Abhinav
Added after 2 minutes:
I am absolutely new to this subject and I dont have enough insight in the subject, that I can do this in a few dayz. I need some help. If anyone can help me on this, I will be thankful to him forever.
Regards,
Abhinav
lna atf54143
u need to read alittile about rf amp design , in some book and u can folow this tutorial
khouly
    abhinavs
amplifier design serenade
designing LNA is skilled full job.
it takes a time.
you have to do your self.
we can guide you if u face any difficulties while designing,simulating or fabricating.
at least read the links given by us.
best of luck.
900mhz lna design tutorial
y can use the MGA53543 to design the NF=2~3,GAIN>10dB and f=2.4~2.5G,it is easy,
if y want to design the nf<1dB lna,use the ATF54143 OR atf55143,it is easy
lna for 2.4 ghz circuits
Hello Frnds,
I am going through a report over net. That report shows the schematic for a LNA designed on 2.4 GHz. I have already gone through the basic tutorials of Serenade. Can anyone kindly tell the components labelled OS1 in the figure.
I have attached the same with this post. Also why is thr a file attached with the 2-port thing. That file is some .s2p file. Can someone plz tell me the details of this simulations.
how to do biasing in serenade
i think the OS1 is open circuit stub used for matching
with the transmission lines
khouly
serenade + rf design
Thanks Khouly for the details. However I am facing various problems which simulation the same on serenade.
First of all I am unable to find the open circuit stub in serenade, which needs W and P as input, i found one which asks for Z and P as input.
Secondly, in transmission lines wat should be label. I left default 'sub' thr but while analysis it was giving problem.
Thirdly, in the 2 port a gave device name as 'at31011' but what should be the file. In the figure its shown at31011.s2p but I dont have any such file. Also further there are other parameteres i need to fill in the 2 port table. Can someone tell me the details for the same.
I know I am unale to do anything [:)] but kindly help me through.
Regards,
Abhinav
Added after 1 minutes:
If not a problem can someone kindly send me a serenade simulation file of the schematic I have posted. I can build my further schematics taking your simulation file as the base.
Thankx in advance,
Abhinav
Added after 8 minutes:
Similarly I am trying to simulate example 4, on page number 9 of the following file:
thr again in the 2 port device, thr we can see device as FET11_3 and file px11_3.flp. Now where to put the .flp file. However in the document the content of the .flp file is also given.
Kindly help me in any one of the simulations. Any one simulation will be enough for me.
Regards,
Abhinav
