[SOLVED] LNA Biascircuit error in ads
microantenna
Newbie level 6
Newbie level 6
while using disignguide to design a Bias Network in ads,it always shows that number of nodes with only one device attached,and it can not generate Bias Network selection,this has bothered me for a long time can anyone know how to solve this problem.By the way way,my ads version is 2022 update.
This is a warning only, it will simulate fine.
But you can connect S1 and S2 to solve this.
--- Updated ---
Shouldn't S, S1 & S2 be connected to ground?
The element with "S" is a virtual test instrument, so this connects to the source node of the device under test.
--- Updated ---
it also did not work,i guess maybe the setting in somewhere is wrong,or Due to version incompatibility
