harryzhu
Member level 3
lmgrd log file
I installed IC5033 and calibre based on Redhat 8.0 and I set these variable in ~/.cshrc:
setenv CDS_LIC_FILE /usr/ENG/lic/license.dat
setenv license_server earth
setenv CDS_INST_DIR /tools/cadence
setenv LM_LICENSE_FILE /usr/ENG/lic/mg.dat:/usr/ENG/lic/license.dat
setenv MGC_HOME /tools/calibre/ixl_cal_2003.4_9
then
$>source ~/.cshrc
$>nohup /tools/cadence/tools/bin/lmgrd -c /usr/ENG/lic/license.dat > \
$>/usr/tmp/license.log
But the lmgrd daemon cannot run up rightly. I check the file '/usr/tmp/license.log' and get these info:
18:32:37 (lmgrd) -----------------------------------------------
18:32:37 (lmgrd) Please Note:
18:32:37 (lmgrd)
18:32:37 (lmgrd) This log is intended for debug purposes only.
18:32:37 (lmgrd) There are many details in licensing policies
18:32:37 (lmgrd) that are not reported in the information logged
18:32:37 (lmgrd) here, so if you use this log file for any kind
18:32:37 (lmgrd) of usage reporting you will generally produce
18:32:37 (lmgrd) incorrect results.
18:32:37 (lmgrd)
18:32:37 (lmgrd)
18:32:37 (lmgrd)
18:32:37 (lmgrd) ERROR: license files have conflicting port numbers
18:32:37 (lmgrd) 1717 and 5280
18:32:37 (lmgrd) Please edit the license files so the port numbers
18:32:37 (lmgrd) on the SERVER line are identical.
18:32:37 (lmgrd) License files include: /usr/ENG/lic/mg.dat /usr/ENG/lic/license.dat
18:32:37 (lmgrd) Exiting
I refer to separated license file for several tools and give them different port, I cannot check any question. What should I do now?
Thanks and Best Regards,
Harryzhu
then
$>source ~/.cshrc
18:32:37 (lmgrd)
18:32:37 (lmgrd)
18:32:37 (lmgrd)
18:32:37 (lmgrd)
Harryzhu
