chirag2239
Member level 3
Hello,
I am creating an LED driver using LM3402HV. When I connect the circuit as shown in attached datasheet, it shows unusual response.
When I connect the R(ON) resistor to pin 7 and then measure the voltage on PIN 8, it reduces to 7V from 40V. My VIN voltage is 40V. My requirement is 36V/480mA. What I need to do to maintain the Vin at 36V on this pin? The value of Ron is 220K. I am driving a strip of 96 LEDs. 12 in series and 8 columns of 12 series connected LEDs in parallel. Do I need a higher capacity power supply?
I have created whole Circuit but at the output, I am getting only 5V. What to do?
Then I disconnected all the parts and one by one, I checked all the components and its voltage, then the problem is same as before. Why the voltage is getting down? Is there any problem in this design? Do I need to increase the input voltage?
Please help me to solve this issue.
Thanks.
Chirag
Thanks.
Chirag
