Peter1960
Newbie level 3
I am using a LM338 with a set no load o/p of 7.1 volts, mounted on a large heatsink.
I need 4.2 amps out, however I am wondering if 20v in is to large,
due to that when I place the load on the output the volts drop to ~3.5 volts.
I am using 120R as the feedback resistor, ie out to variable in, and a 560R to ground.
any suggestion appreciated.
Peter
Peter
