mhamzah3
Newbie level 6
I am building a Step Down Voltage Regulator from 70V to 20V using 2 LM317T chip. The schematic design is attached with this post.
The problem I am getting is whenever I load with the circuit with 0.3-0.5 amps, the voltage is unstable where the output drops from 19.85V to 10V.
On the datasheet, the maximum current that can be drawn from the LM317T is 1.5A but I am unable to draw that much current. The maximum current draw is less that 200 mA to achieve a stable output voltage.
Please help.
Thanks
Please help.
Thanks
