Xenobius
Member level 5
Hi all,
I have several current limit circuits for several LEDs. In another post on this forum we have been through the voltage, led rating, binning of leds and whatnot. I did build the circuit and it worked flawlessly so I moved on to the final version of the circuit. However stupidly enough I added a diode without testing it. I believe I was reading somewhere and it said you always should have a diode!
So here is the circuit - I have a transistor which pulls the ADJ of the LM317 down to ground and effectively killing the lights out. When tested (without the diode) it worked flawlessly as said already however with the diode, the transistor (s) just blew up! I have yet to repair and remove the diode and try again but my question is - what on earth happened? I am attaching the circuit.
1 important thing to note is that actually when the micro controller signal was OFF, the transistor was off, and the leds where nice and bright without issues!
the moment the micro controller started to PWM the transistor (which again worked well without the diode earlier) the transistors just blew up.
Why did this happen? Thank you all
