LM2676 Buck converter Schematic and PCb design in Eagle.
adnan012
Advanced Member level 1
hi,
I have designed a PCB for lm2676 buck convert in Eagle . I want to know that is there any issue regarding nets, via , silk etc. the design files are attached. I have experience in Orcad16 but i have to design small board in Eagle.
  • Lm2676BoardEagle.rar
ur circuit and design are very good.In silk the main thing u have to care about is overlapping,I think in ur design its not there.so dont worry
Thanks for reply.
How GERBER files are generated in eagle ? How via drill are defined?
In eagle there will be 13 files for 2 layer board and 15 files for 4 layer board.There is one step by step process to generate GERBER,I will try to send it today
Kindly generate the GERBER files.
follow this steps
1.ulp>drillcfg.ulp>open.
2.CAM>File>open>job>gerb274x>process job.(gerb274x-4layer-for 4layer)
3.CAM>File>open>job>excellon>process job.
4.ulp>drilllegend.ulp.
5.Enable 20&144 layer in board and generate pdf file.
6.ulp>picknplace.ulp
now u will have 13 files for 2 layer board,just zip all files...that' all
