SiddharthGajjar
Junior Member level 3
- Joined
- Jan 6, 2016
- Messages
- 31
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 289
My input voltage is 5V DC
burst current for SIM900 is 2A
after that my application on SIM900 takes 40mA constant.
so using LM317 with sim900, would it be reliable???
Yes, that "may" be a problem.The problem with a diode may be an overvoltage condition with very low load, as well as significantly larger drop (loss of regulation) on maximum load.
My GSM modem continuosly transmitting garbage value...
You did not read the datasheet for the LM317:i was testing it in range of 3.2 volt to 4.45 volt range.....
with lm317 regulator attached with 5V input voltage,
adjust and output pins are short to get 4.45 vtg.
