LIVE used GND in energy meter
There is a 664 K to 1K attenuation of the line voltage before it goes into the IC. I can't see any connection to the neutral at all.
Frank
In sheet one, neutral presents HIGH in the circuit while live present low in the circuit.
If you give Live to HIGH and Neutral to GND then SHUNT will go to neutral side.
As a result free energy seekers can get free energy by connecting load's neutral to earth instead of connecting it to meter's neutral output.
(shunt bypass using earth)
