nearxosp
Newbie
I am working on a small project. A Liquid Solution dispenser, that mix a liquid solution with Water in a tank and after that it fills a bottle with the mixed solution.
On the project there are :
- 2 buttons to start the process with 2 different mixing ratios of the liquid. (rgb leds on each button for the different states, standby, mixing finish, etc)
- 1 inlet solenoid valve for the water feed
- 1 Limit switch that detects if the bottle is placed.
- 1 float switch in the tank that detects when the tank is full and close the inlet solenoid valve for the water.
- 1 peristaltic pump that works on a timer that fill the tank with the solution before the Water.
- 1 outlet solenoid valve to fill the bottle after the mixing.
I would love to have some feedback on the Circuit and the PCB as is the first time i am design a PCB.
Thanks in advance!
Thanks in advance!
