Linux platforms for IC 5.1.41
eng_Semi
Full Member level 6
Full Member level 6
Egypt
Dear ALL,
Does any one try to install IC 5.1.41 on any linux platform rather than RedHat Enterprise Linux ??
Does it work well ??
Thanks in advance
Re: IC 5.1.41 platform
I am running it from Fedora Core 4 and Fedora Core 3. I have seen it run on Suse 9.3 and 10 (beta version). I am confident that you can install it on almost any Linux version today, since they are very similar, however, Cadence supports only RHEL 2.1 and 3.0.
In general works fine, only thing you need is to set LD_ASSUME_KERNEL to 2.4.1 an properly set environment variables for Cadence.
IC 5.1.41 platform
eesoko is right , i have install cadence in Fedora Core 4 and work well after set LD_ASSUME_KERNEL to 2.4.1,thanks
regards
IC 5.1.41 platform
friends of mine use it with rh7.2 & rh8.0.
Hi
...And:
Mandrake 9.2
Redhat AS 2.1 OR AS3.0
tnx
IC 5.1.41 platform
I'm using it in Debian 3.0 (Woody), 3.1 (Sarge) and now in its testing version (Etch) without any error even no need to set LD_ASSUME_KERNEL=2.4.1 However, there is a trick to use its waveform viewer.
Supported platforms are redhat Linux7.2, 7.3, 8.0 and EL2.1, EL3.0.
BEST!
Which is ?!!!!
eng_Semi said:
Which is ?!!!!
Add this to your .bashrc in order to use "wavescan" as viewer
export MALLOC_CHECK_=0
OR
add this to your .cdsenv to use "AWD" instead
asimenv.startup cds_ade_wftool string "AWD"
