Link Training with IO DELAY
beginner_EDA
Full Member level 4
how to implement link training with IO DELAY in Xilinx ultrascale FPGA?
Any idea or reference design?
Thanks
In essence - "link training" is the process of finding the safest sampling point at receiver to avoid timings violations and achieve a robust link.
In the Ultrascale family the recommendation is to use the "bitslice" component.
Google XAPP1274
Yes.
The "bitslice" is an IOSERDES, IODELAY and FIFO aggregated into one primitive.
Before Ultrascale - series 7 had these separately.
The new approach is what Xilinx calls: "Native Mode".
The old approach (Series 7) is called: "Component Mode".
You can still use "Component Mode" with Ultrascale - however, it's inadvisable unless you have a good reason to do so...
https://www.youtube.com/watch?v=ihk7YbZqCKA
Enjoy
@shaiko
This solution seems like source synchronous. Is there one which is not source synchronous and also support smaller FPGA like artix?
There is no specific protocol. I have just 4 I/O pins on TX end and 4 I/O pins on RX end and using 2 in one direction and remaining 2 on another direction at each end. At the moment I send some known pattern from each end and verify on another end and then send the data and it works at 100 MHz.
At 100MHz - why do you want to use a SERDES ?
Why not implement a simple synchronous interface (like SPI) ?
