link command fail in Design compiler
Jerry Yau
Member level 4
Member level 4
Hi all,
What reason will cause link command fail when I read a compiled DB file into design conpiler?
Of course, the library is correct.
And I compile my design with worst case library and generate worst sdf file but how to generate best case sdf file. Thanks
Use netlist instead of DB; DB contains all compile information including
library db.
Try reading netlist and link best case library.
