Lines outside Layout editor Altium
ctzof
Full Member level 3
Full Member level 3
Munich
Hallo,
Ive accidentally move some lines out from the main layout editor in Altium and now I cant access them so the appear in DRC as net antenna Any thoughts how I can access and delete those lines?
If you know which net they belong to, right click any trace and select "Find similar objects" then select the net to which the missing traces belong and click Apply. Now the invisible traces will also be selected, so simply press Delete to remove them from the board.
Reactions: ctzof
    ctzof
