Junus2012
Advanced Member level 5
Hello,
I have a linear temperature to frequency converter. I plotted the output frequency versus the temperature.
I have confusion on the simulation of the output accuracy and the linearity.
Before I give you my procedure, is it possible to simulate the accuracy or it is only a real measurement quantity?
Here is my procedure for calculating the accuracy
1. I take the average sensitivity of the sensor output (S=average(df/dt))
2. I plot an ideal straight line (f= f0+S.T), where fo is the sensor output frequency at zero °C
3. I subtract the actual sensor output from the linear line
4. Accuracy error (in °C)= subtraction result/S
For the linearity calculation I used to import the result to Matlab and
1. Plotting the best fit line from the output signal
2. Subtract the both signals
3. linearity (%)= (subtraction result / (fmax-fmin))*100%
Thank you for your help
Best Regards
Best Regards
