tecmec
Newbie level 5
Hello, I I'm looking for some input for designing a simple linear power supply for a microcontroller circuit I plan on powering from a vehicles power circuit.
I am using a LM7805 linear 5V regulator, and I currently have a 47uF electrolytic cap and a 220nF ceramic on the input side of the regulator, and a 100nF ceramic cap on the output side. (there are 100nF tant caps around all my ICs too, just fyi).
I haven't actually tried this in my vehicle yet, but I believe my power supply circuit is not adequately filtering my power. My reason is this: I am currently powering the circuit using a cheap 12 power supply plugged into the wall. When I plug something else into the same outlet, or switch something on or off on that outlet, some of the noise gets passed though the cheap 12 supply i'm using (not my circuit), and in tern gets passed through my 5V power supply circuit (my design). The noise that I'm seeing (on my 5v rail) is about a short 10MHz ring. This wreaks havoc on my instrumentation amplifier and in tern my a2d readings.
My load is typically 35mA, but when one of my realys is on on my board, the circuit uses about 235mA.
Could someone please provide some insight on filtering this? My cap choices are probably all wrong.
