sefton
Member level 2
I am using a linear regulator (LM1117). For reasons that I will not go into here, I have to connect 3 caps (470uF each) to the output. The effective ESR of theses caps is less than 0.05Ω. In the data sheet for the LM1117 they recommend an output cap with ESR of 0.3Ω - 22Ω. I remember reading somewhere that if the ESR is too low there can be instability although I don't remember if it was for switchmode or linear. The data sheet specifies a minimum ESR value of 0.3Ω so I am worried about that. Should I connect a series resistance of 0.27Ω ?
Any comments or suggestions will be appreciated.
