CVT
I need advice from knowledgeable analog (emc) designers regarding a choice between a linear PSU or switch-mode PSU for laboratory use.
At the moment I am busy with a sensitive circuit with low level signals containing ADCs, Op Amps and voltage to frequency converters. I had a closed frame switch-mode PSU driving another piece of equipment in my office. I knew that it would be noisy but I under estimated the influence it would have on my sensitive analog circuit which it is not even connected to it. I know this is because of radiated emissions and susceptiblity.
In future I will be doing even more designs with such sensitive circuits. I want to buy a general dual output laboratory bench PSU that will have very low radiated and conducted emmisions.
My question is:
Will a good quality linear PSU always be much better than a good quality switch-mode PSU for such sensitive work?
Maybe there are good modern implementation of Switch-Mode PSUs that are comparable to good Linear PSU?
Please elaborate on your views or point me to good switch-mode PSU i.e. noise comparable to linear PSUs.
I am looking at:
Linear PSU (2 x PAN60-6A) at a cost of $4800 (https://www.kikusui.co.jp/en/product/detail.php?IdFamily=0003)
Switch MOde PSU: (1 x XPF 60-20DMHV) at a cost of $3000 (https://www.signaltestinc.com/v/vspfiles/assets/datasheet/Sorensen_XPF_Datasheet.pdf)
I am not concerned about spending the $4800 if I have to.
My question is:
I am looking at:
