linear power amplifier with pulse VCO
goatmxj666
Member level 3
Member level 3
hello,
I want to design a power amplifier that operates at 5 GHz.
The output of the VCO circuit that I can use is a pulse signal with 5 GHz.
If the output of the VCO is a pulse, then do I have to use a non linear power amplifier only?
Can I use a linear power amplifier with an LC filter after it to make it a sine wave?
The LC second-order (low-pass) filter is effective at shaping a waveform into a sine wave, if resonant frequency matches incoming frequency.
L & C values need to be customized to your load and frequency.
It's possible to build a sine-wave oscillator which automatically detects LC resonant frequency, and creates oscillations at that frequency through your load.
Of course there's a challenge operating at 5 GHz more so than at slower frequencies.
I think the output of your VCO is not a pulse, but it is a square-wave signal.
Yes, you can use an LC filter (LPF or BPF) at the output of the VCO to make it sine wave.
