CTT
Newbie level 6
Hello,
Is there anybody who already designed a PA that should drive a SAW filter ? Should we provide a particular output impedance to the SAW to
reduce VSWR ?
Lots of design papers says that you should transform the load to the optimum load to have best efficiency. Suppose I have a 50Ohm SAW
filter that is terminated with a 50 Ohms impedance and that my optimum
load is 10 Ohms. Suppose also that I use an open collector output + a RFChoke. I need to use an additional impedance transformation (1:5)
to obtain the require 10 Ohms but if I do that the source impedance that
sees the SAW will not be 50 Ohms at all ... is that correct ?
Is there anybody who designed and measured a linear PA + SAW filter already that can help me ?
Thanks
CTT
reduce VSWR ?
Thanks
CTT
