So I was able to find a way around this problem:
-I used connectors in capture CIS with the same number of pins as my corresponding pads.
-In the properties of the parts in capture, i put the correct footprint
-I exported the netlist
-I imported this netlist into Allegro.
-Then I was able to see rasnets and create connections without getting a DRC.
Now my problem is the following: I added more structures in the schematic; I removed some pins from my package to match the schematic. But I cannot seem to see these updated footprints on the board.
For instance, one of my package footprints had 16 pins, i removed pins 1 and 4 and saved it the package symbol. When I go back to the board to update the place the same package it is still the 16 pin version. And when I try to import the netlist i get the error:
"ERROR(SPMHNI-196): Symbol 'XYZ' for device 'X_XYZ' has extra pin '1'.
ERROR(SPMHNI-196): Symbol 'XYZ' for device 'X_XYZ' has extra pin '4'.
How can one update the footprint library in Allegro PCB 16.2?
Thanks.
RMA
