Squirtle
Junior Member level 2
Hello guys,
We are designing multicouplers which consist of LNA, power divider and cavity filter. When LNA is connected before filter, it usually fails, the amplifier PSA4-5043 breaks down. The reason of failing might be presence of too much of other band's signals in the area which cause LNA to drive more current because i noticed that when i applied higher power to the i/p of LNA, it drives more current so if i put current limiter to the DC bias of LNA, maybe i can stop it from breaks down. Deos it work? and if i put power limiter before amplifier, can i prevent it from drawing more current?
Thanks,
Thanks,
