Library setup and hold time requirements..
bschaitanya
Junior Member level 2
Hyderabad
Hello All,
Can anybody explains on what parameters library setup time and library hold time requirement depends/ characterize ?
In my case I pretty much observed a change in setup time requirement for a ram especially by adding buffer and without that..
Here is an example
By default:
library setup time -0.325
on added buffer:
library setup time -0.192
So, I cum to know Tran value shows major impact on setup time requirement . Is there any other parameters too impact this..
The setup/hold values in the library are characterised based on different transition values of clock and data (or addr or...) pins. No dependency on output load. And, for sure, these value are different in the different corners (different PVT conditions).
Thanks oratie..
I checked manually by changing output load there is no change in the setup time requirement.It remained same.yeah no dependency on output load.
