library manager errors and poor ic5.0.33 performance
nijMcnij
Full Member level 1
Full Member level 1
Hello all
i have installed IC5033 on a P4 laptop under RHEL3.0 ES...no problems with the installation process.
LM won't run....i receive the following error
"Incorrectly built binary whichaccesses errno, h_errno, or _res directly. Needs to be fixed"
CIW says:
"unable to connect to library manager (60 tries)"
your assistance is much appreciated
Try Redhat 7.3, it's the most suitable Linux OS for EDA.
thank you for your reply, but i have serious doubts that RH7.3 will solve the problem...since i am using cadence 5033 on a intel xeon server with RHEL3.0 ES with no problems what so ever.....trying it at home on a personal laptop was the issue.
I think executing file is corrupted. Try reinstall or check the files' integrity...
reinstall......that i can do
check file integrity.......no idea
but i have to point out that the installation went extremely smoothly.
thks
