Li-ion charger for replacement battery
Drone123
Newbie
Newbie level 2
Hello,
Im sorry, this question is probably VERY basic for all of you, but I cant find an answer anywhere- so any help you could offer would be much appreciated!
I have a small drone that has dc 5v 2000mah batteries - it charges directly through the drone via a usb cable connected to the drone.
I wanted to get some replacement batteries (955565 on amazon, not quite the same- dc 3.7 at 5000mah), but I haven't any idea how to charge them without using the drone. Even then, would it work? I cant find the chargers for these batteries...
I have never sen 5V batteries. You have a photo or manufacturer + part number?
--> internet search: "Li-Ion charger module".
would it work
can you define "work" and "not work"?
How do you test it?
Klaus
How do you test it?
Klaus
Hello,
Im guessing the 5v is the max charge.
I suppose "working" would mean i can use the drone to charge the new batteries
--- Updated ---
Hello,
Or, even a charger module with a usb connection...
Write your reply...
LaTeX Commands Quick-Menu:
