Li-ion Battery charger need help
maxim10373
Full Member level 1
A Lithium iron Phosphate battery voltage is 3.2v and capacity is 5000mAh.
what is the charging current if I make a charger for single cell ?
Data sheet said that 1C rating.
if 1C =5 amp for one hour that means a 5amp charger enough ?
awaiting reply
maxim
What exactly does the datasheet say? 1C is typical or recommended charge current, or maximum charge current?
(Why don't you post a link to the datasheet?)
Doesn't the manufacturer provide additional documents on how to charge the battery?
Usually Li-Ion need constant current charging, but only up to a given cell voltage (very tightly tolerated), then the current needs to be reduced.
If you don't follow this rule you risk explosion and fire.
There are many documemts from battery manufacturers, charger IC manufacturers, universities on how to correctly charge a battery.
Btw: there's a good reason why there are dedicated cgarger ICs. I'd use one of them.
Many (unexperienced) say they are complicated. But indeed many of them have optimized charging scheme, tight voltage references, power saving techniques and many other useful features included...
Klaus
Thanks for reply.
i have attached the datasheet here.
regards
maxim
  • 32650 LiFePO4 Battery Spec.pdf
May I ask why you didn't read the datasheet?
It is no Li-Ion, it specifies the charging method, it specifies the charging current, which is not 1C...
Klaus
Hello Maxim, there is a curve for 1C charging in the data sheet - but really 1/5 C to 1/3 C is a better charging maximum, i.e. 5/3 amps for a 3 hour re-charge ...
