HSSN
Newbie level 3
I am looking for a level shifter with low phase noise which shifts from 1v to 0.75v input common mode and swing from VH=1.2v & VL=0.8v to VH=0.95v & VL=0.55v
am working with CML dividers @ 8GHz so the simple resistor will limit the frequency and when i used a simple inverter it contributes about 90% of the phase noise ???!!!
the phase noise profile before the inverter was (fc=15k and noise floor =-149dBc/Hz ) but after the inverter added (fc=100k & noise floor =-130dBc/Hz)
the simple resistors need also higher current to be injected ??
i didnot measure the line impedance
