Level shifter isn't inserted
YakDamBam
Newbie level 6
Newbie level 6
I'm working with Design Compiler and UPF to insert level shifters and isolation cells into a design
I have two power domains and want to insert level shifter between two power domains
I write UPF associated with level shifter like this
set_level_shifter HtoL_sig_to_msb \
-domain SWITCH \
-applies_to inputs \
-rule high_to_low \
-location self
During synthesizing, there are errros and there aren't level shifters in netlist confirmed by VCS
So, I wonder if it is inserted in either the synthetic flow or the physical flow.
If level shfiter is inserted in synthetic flow, why level shifter isn't inserted in my case?
-domain SWITCH \
-rule high_to_low \
-location self
it is easier to handle MSV during physical synthesis and ignore it during logic synthesis.
you have missing these options like -source ,-sink ,input_supply_set and output_supply_set
