tomerbr
Junior Member level 2
I have a project where I feed line level amplifier from a high gain amplifier.
The main problem that I have if with the gain difference so I introduced an attenuator which solved my problem when the high gain amplifier was at his peak volume but now I have a problem with the low level signals when the high gain amplifier volume is very low.
I would like to build an attenuator that will start to work only from a certain input level, is it possible?
I have searched the net and could not find how to do it although I am sure there is a way.
I saw for example this device https://www.ti.com/lit/ds/symlink/tpa6132a2.pdf but the problem is that the max input levels are 2.2V (HPVDD + 0.3), the output level of high power amplifiers can reach 15-20V (even more) so I guess this is not an option.
Any help is greatly appreciated.
Tomer
Tomer
