wjccentury
Junior Member level 2
lock up latch
Hi, everyone,
We know, DFT Compiler inserts lockup latch between adjacent scan FFs if they are triggered by different clocks and the test clock waveforms are the same.
Use the command set_scan_configuration –add_lockup ture
However, in this case, how can we set false path when doing test mode STA ?
Now, we use the test clock that can be controled on top level. If we don't want to insert lockup cell. Does it means we should control the test clock timing properly?
Is there something we should think about ?
Hi, everyone,
