lef file(*.lef) format specifications
blue1988
Junior Member level 2
hi all,
i need the Cadence lef file(*.lef) format specifications. it is useful to me.dose somebody have one ?please attach it or
give a link .thanks!
best regards,
gen0357,
thanks,can you attache the file or give a link?i don't have one.
kumar_eee,
thanks for your document.regards.
Guys, I have a question regarding Cadence LEF format. If you're using Synopsys LEF format, you can have either strong or weak connections. Here is an example:
Strong connection
PIN A
DIRECTION INOUT ;
USE GROUND ;
PORT
LAYER METAL6 ;
RECT 48.86 0 54.18 3.64 ;
LAYER METAL6 ;
RECT 81.34 0 86.66 3.64 ;
END
PORT
Weak connection
PIN A
DIRECTION INOUT ;
USE GROUND ;
PORT
LAYER METAL6 ;
END
PORT
LAYER METAL6 ;
END
PORT
So the questions are.
1. How PnR tool handle this.
2. Has Cadence LEF something similar and if yes, the same question, how Cadence PnR tool handle this.
Thanks a lot.
Hi SSTA,
We using the cadence lef.But all i find in the lef file is the strong connection.I have not seen the weak connection. Sorry for that.
Hi SSTA,
Thanks for the info, blue1988. So you meant that you never met Cadence LEF with weak connections, right?
yes ,never met the weak format.
