itsallgood
Member level 2
Hi guys,
I've been a member of this forum since 2002 - and i still cannot work this out. You think it's time for me to get a new hobby? :roll:
I have purchased 5m of LED strip lights, with the following info...
I have also purchased these drivers (without really knowing anything - i just saw the "12v" and thought they would be ok...
Please can you tell me if these drivers are sutible to run my LEDs - and at what length. Could i run the whole 5m on 1 driver? Did i buy the right drivers?
Thanks so much for the help! It's really appreciated
● View angle:120°
● Working Voltage: 12V AC
● LED Quantity: 300 leds/5 Mete
● Working Current/meter: 0.35-0.4A
● Output power: 20-24W /5 Meter
● Working Temperature:-20 to 50°
● Waterproof
● Luminous Flux: 300-350 Lumens/Meter
● Size: L500cm (5M) x W0.8cm x T0.25cm
● LED Driver 12 watts
● Output Voltage (V) 12v DC
● Input Voltage (V) 240V 50/60Hz V
● Power output 0.5 - 12w
● Max Ambient Temp (deg. C) 40 deg. C
● Max Case Temp (deg. C) 80 deg C
