snikrepmada
Newbie level 1
2 led projects
I hope someone can help me out with my project, I am very new to microcontrollers and need someone to tell me if I am even looking in the correct place.
What I need:
1. Small form is a must.
2. I need it to run off of one or two 2032 button cell batteries (as size is a huge factor).
3. I need to control two LED of different color.
4. I need two press switches to control the entire thing.
Operation:
Pressing both switches at the same time turns on/off the LEDs. Pressing one switching dims one LED and brightens the other LED, by one step. Continuing to press the switch continues to dim one LED until it is off and brightens the other until it is fully on. The other switch does the same process but the LED are reversed. I hope this makes sense. I need a ten minute timer that shuts off the LEDs and when you turn it back on it returns to the same setting as when it turned off.
It would be greatly appreciated if anyone could help me out with this project.
What I need:
Operation:
