matrixofdynamism
Advanced Member level 2
I have found that the human eye responds nonlinearly to color brightnesses and the response is different for each color. OK, neve mind that.
There are multiple single color LEDs on the board and also some RGB LEDs. In order to get uniform brightness on the single color ones, is it sufficient to connect the same (value & tolerance) resistor to all the LEDs or should I develop a constant current source using transistors? Doing so will require me to have a lot of matched transistors which I do not think can be found. There are 120 LEDs. I ask this since LEDs are current controlled devices.
