Led lighting project for displaying unicode characters.
Prashantakerkar
Member level 4
Member level 4
Is it possible to display unicode characters / Symbols with Led?.
Examples : Copyright symbol, @, #, £ etc
If yes, How?.
If no, why?.
Or is it some unicode characters can be displayed but not all ?
Thanks & Regards,
Prashant S Akerkar
"unicode" is just the code scheme for a string. It is related to a programming language (and data storage)
But it is not related to a display.
The display datasheet should tell you what characters it can show.
With some displays you can define your own characters.
Klaus
Thanks.
I mean similar to digits 0 to 9 & 26 alphabetic characters, Can the Unicode characters be displayed using 7 / 9 / 14 etc segment Led display ?
Examples : £ , @, # , °, ®, ¢ etc
Thanks & Regards,
Prashant S Akerkar
Again:
--> Read the datasheet.
You can try on your own, how "£ , @, # , °, ®, ¢ " should look on a 7 segment display.
Do an internet search for unicode. You will find out that there are more than 1million possible characters.
A 7 segmant is able to show 127 different combinations - not all may be recognized as valid characters.
Klaus
Thanks.
Whether a 14 or 16 segment Led display can display all unicode characters are to be traced.
Thanks & Regards,
Prashant S Akerkar
Please do a little research, datasheet reading and testing on your own.
Klaus
LED matrix that's what they use for all that stuff, not 7-segment displays.
You can map the most complex and/or largest unicode or whatever language character onto a piece of graph paper - really high tech stuff. When you know how many maximum squares are filled by a character in the vertical and the horizontal planes, you can count how many LEDs you will need to make a square, rectangle or circle or any shape in fact LED matrix.
Think London, New York, Mumbai, Tokyo, anywhere with huge LED advertising matrixes/screens, or modern bus numbers and destinations, or airports and train stations - they all use (LED) matrixes of small and building-size dimensions.
