LED / LCD / SW design help
baba_sanfur
Newbie level 5
Newbie level 5
Hi all,
I am working on a project that contains microcontroller with 12 GPIOs. I need to connect LCD + 12 LEDs + 4 keys to those GPIOs. So I'm thinking about the circuit I attached.
The LEDs / Keys / LCD will share operating time. The problem is the LEDs: those leds will be operated by pulses (reduce time / power consumption). In order to share "CPU" time for all those components, I would like to increase the current to the leds (the current pulse's amplitude) to make them brighter (low time share = lower brightness).
How can I connect the minimum possible drivers to the leds? (NPN + resistor ???)
Do you have better idea how to connect those components? (SPI / I2C / Shift reg are too expensive)
Thanks,
Nir
